AUTOPOWER » FORUM
[ AutoPower ] [ Forum ] [ 5-Serien ]
BMW 530i -01 Överhettad eller visar den fel temp?
Visad 646 gånger
Besvara
Sida: 1 2 AutoPower Forum Första sidan (ej tillgänglig)Föregående sida (ej tillgänglig)Nästa sidaSista sidan
Inlagd av Fråga
Antal inlägg180st
Postad/Inlagd2020-10-24 14:45
530i -01 sedan manuell
535i -89 sedan manuell
Sorry grabbar, hoppas ni förstår engelska bra, orkar inte skriva hela historien igen.
I have a 530i 2001. 2 years ago i overheated it. Beacause of a crack in the plastic on the radiator (the coolant leaked out).
I replaced the radiator, waterpump, thermostat and the fan clutch. Then i ran perfekt for 2 years, till yesterday.
I drove it pretty hard... I looked down and the temp was in the red, i killed the ignition direct, and let it cool off with the enginge off, and ignition on with full fan and full warmer... For like 2 min... Then i sat in the car and the temp was down 2 normal in just 2 min?!
So i bringed up the digital temp gauge in the cluster to have full control over the temp.
Nothing was leaking from the engine or something...
I fired up the car and continue to drive... And the temp was rising to like 110°C... But when i set the heater to defrost, and max warm and full fan, the temp dropped down to like 95-100°C.. so i continue to drive like that for 1 hour.. then i checked the car this morning...
No coolant missing, oil looks fine..
The electric fan is working...
Any ideas? Check all fuses and connectors?
Så alltså. Jag tror inte att den blir överhettad utan att den visar nog fel temperatur bara... För motorn/kylarslangar/kylare känns ej varma. vart sitter temp givaren för tempmätaren i bilen? Är de samma tempgivare till analoga tempmätaren och den digitala som man kan få upp i clustret?
Mvh Emil Palm           IP: ...[147.125]
Annons
Antal inlägg3.174 st
Postad/Inlagd2020-10-24 20:38
Anmäl svaretAnmäl svaret
750iAL -99
Hallo Emil,
Hoffentlich verstehst du auch Deutsch gut. Ich bin auch recht muede. :)
Probier mal realoem.com.
/Lennart           IP: ...[.152.18]
Antal inlägg180 st
Postad/Inlagd2020-10-24 20:54
Haha, nu va du rolig lennart :):):)
Har kört bilen ca 10-15 mil idag å den verkar ha lagat sig själv nu... Jätteskumt...           IP: ...[.27.199]
Antal inlägg180 st
Postad/Inlagd2020-10-24 20:55
Ja läste även ut bilen idag, inga felkoder heller           IP: ...[.27.199]
Postad/Inlagd2020-10-24 21:11
750iAL -99
Nu har jag piggnat till. :)
Nr 4 här kan vara boven,
[LÄNK]
Men eftersom felet lagat sig självt - vilket ju aldrig är att lita på - kanske det bara är dålig kontakt eller glapp någonstans?
Men temp-sensorn kostar väl knappast skjortan,, så om det börjar krångla igen, är det kanske värt ett byte.
Antal inlägg454 st
Postad/Inlagd2020-10-24 23:41
Alpina B10 BiTurbo -93
750i -00
540i/6 -94
520iT -96
Behöver du en #4 så har jag en över.
(miss)Lyckades med köpa två st Hella 6PT 009 309-541 till E38:an med några månaders mellanrum.
Ny i kartong, 100 + frakt?
          IP: ...[6.42.42]
Antal inlägg180 st
Postad/Inlagd2020-10-25 09:53
Vad exakt gör nr 4?
Den har nog inte lagat sig själv helt endå... Tidigare låg den på 97°C stabilt... Nu ligger den på uppåt 105-106 grader om ja har normaltemp i bilen... Vill jag få ner motortempen så lär ja fläska på full värme å full fläkt...
Kanske termostaten har hakat upp sig? Den e ju trots allt elektrisk.. Bilen har endast gått typ 300 mil senaste 4 månaderna pga rostlagning...
Kikade på autodoc, de fanns 3 olika termostat temp å välja på till min... 85/97/101 grader. Vilken ska man ha? Å varför finns de 3 olika?
Mvh Emil           IP: ...[.96.137]
Antal inlägg23.358 st
Postad/Inlagd2020-10-25 10:17
Termostaten är inte elektrisk, däremot finns det ett värmeelement i den som är eldrivet - den värmaren använder motorstyrningen när den vill kyla ner motorn extra mycket under extrema förhållanden, då värmeelementet "lurar" termostaten att öppna upp mer än kylarvätskans temperatur gör...
Om den blir för varm "på riktigt" (dvs. inget sensor-/givarfel eller liknande) skulle jag gissa på att impellern på vattenpumpen har lossnat - ganska vanligt fel.
Lita inte på autodoc eller annan näthandlare - gå till realoem.com och knappa in dina sista sju symboler i chassinummer så får du fram rätt delar (inte alltid 100% säker men betydligt bättre träffsannolikhet än näthandlarnas).
BMW – Weltmarke aus München!           IP: ...[.158.70]
Antal inlägg180 st
Postad/Inlagd2020-10-25 13:22
Men om impellern lossnat då borde den ju gå tokvarm å koka hela tiden?           IP: ...[.96.137]
Postad/Inlagd2020-10-25 13:25
Det beror på....den kan ju sitta "halvlöst" och fungera intermittent...men då lär den bli sämre snart...
Dessutom är det viss självcirkulation i systemet.
Hur långt har bilen gått och har vattenpumpen bytts tidigare?
Det är som sagt ett ganska vanligt fel att impellern släpper från axeln.
Antal inlägg180 st
Postad/Inlagd2020-10-25 13:31
26k mil.
För 2 år sen böt ja kylare, vattenpump, termostat och viskokoppling.           IP: ...[.96.137]
Postad/Inlagd2020-10-25 13:37
Hur långt har bilen rullat sedan bytet?
Vad var det för fabrikat på pumpen?
Antal inlägg180 st
Postad/Inlagd2020-10-25 13:43
4000 mil ca... Vet ej, nån billig på autodoc med plastimpeller           IP: ...[.96.137]
Antal inlägg180 st
Postad/Inlagd2020-10-25 13:45
Hallå där, kolla in SWAG Vattenpump i AUTODOC-appen [LÄNK]
Hittade på den           IP: ...[.96.137]
Antal inlägg180 st
Postad/Inlagd2020-10-25 13:52
Glömde nämna att ja även böt kylarlocket           IP: ...[.96.137]
Postad/Inlagd2020-10-25 13:55
Swag/Febi Bilstein är väl ett mellanklassmärke - kan vara lite ojämna i kvaliteten om jag fattar det hela rätt - vissa saker är väldigt bra och andra mindre bra...
Har du känt på båda kylarslangarna?
Om den övre är förhållandevis kall, kan det tyda på dålig cirkulation.
Även termostaten kan hänga sig i stängt läge i värsta fall och då blir det dåligt flöde.
Nu kommer jag inte ihåg exakt hur det ser ut på din bil, men på E46:an och E39:an (M52tu och M54) så såg man en vattenstråle som kom in i exp-kärlet vid motorn igång när locket var öppet - då såg man att det var cirkulation i systemet.
Kika hur det ser ut på din bil.
Antal inlägg180 st
Postad/Inlagd2020-10-25 14:04
Dom är varma båda två... Aa juste de minns jag att de va en stråle högst upp där.... Ja ska kolla om de fortfarande är så 👍           IP: ...[.96.137]
Antal inlägg180 st
Postad/Inlagd2020-10-25 14:44
Den cirkulationen man ser i expansionskärlet... De kan man även se med motorn avstängd å tändning på... Ifall motorn är varm då så går de nån typ av cirkulationspump..
Jag var ut å tittade på detta nu, å jag såg att den strålen var mycke svagare nu gämfört med när jag kollade de sist i våras nångång...
Någon som vet vart den cirkulationspumpen sitter nånstans?           IP: ...[.96.137]
Antal inlägg180 st
Postad/Inlagd2020-10-25 15:19
Jag var ute å kolla igen nu, cirkulationspump en går när fläkten i cupen är på, även fast motorn är kall           IP: ...[.17.132]
Antal inlägg1.934 st
Postad/Inlagd2020-10-25 15:51
130i E81 -08/09
M-sport
(325xi E90 -06 såld)
(323ti E36 -99 såld)
"Är de samma tempgivare till analoga tempmätaren och den digitala som man kan få upp i clustret?"
Ja
Är den uppe på rött vid 105°C?
Det är bara döda fiskar som följer med strömmen.           IP: ...[210.244]
Antal inlägg180 st
Postad/Inlagd2020-10-25 16:18
Nej mätarn står spikrakt upp när tempen är mellan 75-120... Över 120 så börjar den stiga sakta           IP: ...[.17.132]
Sida: 1 2 Första sidan (ej tillgänglig)Föregående sida (ej tillgänglig)Nästa sidaSista sidan
Besvara
Användarnamn:
Regler för forumet
© 1997 - 2021 AutoPower.se
PowerBörsen
Senaste 5 BMW
BMW 320i Coupé  -09
Pris: 105.000:-
BMW 320d xdrive  -16
Pris: 205.000:-
BMW 335D  -16
Pris: 300.000:-
BMW 530i LCI N53  -07
Pris: 135.000:-
BMW 320d touring m-sport  -14
Pris: 199.000:-
