Har du raderat och felet kommer tillbaka? Inga andra felkoder?
"U010E this code tells you the ECU cannot communicate with the DEF control unit. If errors like this occur, the car should give you a little time (in terms of miles) to take it in for repair, but you should have gotten warning messages well before it shut down. The car will indeed shut down if you either don't have DEF fluid or there is a communication error with the controller."
